Author Topic: BPEL in version 7.5  (Read 4526 times)
philchudley
BPEL in version 7.5
« on: February 23, 2009, 07:41:52 pm »
Hi All
Hope this is the right place for this post. In version 7.5 currently in Beta, BPEL is supported as beging generated from a BPMN diagram.
Does anyone know how?
For the life of me I just don't get it. I can create the BPEL diagram and are presented with the correct dialogs for connecting to webservices etc. But where is the BPEL generation?
Fot me, this one of the most attractive features of version 7.5 ... so help please!
Models are great!
Re: BPEL in version 7.5
« Reply #1 on: February 24, 2009, 08:03:36 am »
To generate, first make sure you've set EA to use the Business or Ultimate editions from your beta test dialog.
You can then Right-click on the BPEL Process element and select the BPEL | Generate BPEL context menu option. The Generate BPEL dialog displays.
VK
« Reply #2 on: February 24, 2009, 04:21:51 pm »
The Enterprise Architect Example file (EAExample.EAP) has a sample BPMN 1.1 model from which BPEL can be generated. If you have installed Enterprise Architect 7.5 at the default location, open this file:
    C:\Program Files\Sparx Systems\EA\EAExample.EAP
The BPMN model package, within EAExample.EAP, is in: System Model -> Implementation Model (PSM) -> BPEL Example.
« Last Edit: February 24, 2009, 04:22:44 pm by vkumar »
philchudley
« Reply #3 on: February 24, 2009, 08:03:33 pm »
Thanks guys, I'll give it a try!
Models are great!
