Author Topic: Java import statements by code generation  (Read 3844 times)
du-it
« on: December 22, 2005, 08:15:29 am »
Is EA able to resolve inner classes for automatic  import statement generation?
I have a class which contains (static) inner classes. In a separate class I use such an inner class. When I put a dependency arrow between these two classes in a diagram the import statement 'forgets' the surrounding class of the inner class.
class A{
   static class B{
   }//end inner static class B
}//end class A
class MyClass{
}//end myClass
I set up a dependency between MyClass an class A.B (MyClass uses A.B somewhere but has no instance field of A.B).
The generated import statement is:
import B;
instead of
import A.B;
A problem of EA or do I have to consider some settings or so?
Thank you,
Dirk
