Author Topic: Deployment Diagrams - Package Contents  (Read 3741 times)
canderson
« on: March 25, 2009, 01:11:10 am »
I'm trying to put a deployment diagram together.
In my project browser I have my components listed in different packages according to the vendors of those packages.
I have this model in an EAP (mdb) file.
When I drag a package onto the diagram it shows the package as a  box that looks like a tab control (with only 1 tab) and the contents of the package listed with the component icon from the project browser/tree.
I recently upgraded this model to a MySQL database.
When I drag a package onto the diagram in this model is shows the package as a box that looks like a tab control (with only 1 tab) but it does not show the package contents?
Is this a setting somewhere or a bug?
Luckily I still had the old EAP file as I had to go back and try it in that model to prove I wasn't going insane!  :)
(FYI - I'm using EA version 7.1 build 828 - the corporate version).
CA.
« Last Edit: March 25, 2009, 01:12:16 am by canderson »
canderson
Re: Deployment Diagrams - Package Contents
« Reply #1 on: March 25, 2009, 02:36:57 am »
I did some more research into this.
TEST 1
I created a new project (EAP) file.
I added a new package (Deployment diagram) to the root node, 'Model'.
I added a diagram under the deployment diagram package.
I also added a new package to the deployment diagram package.
I added a new component to the package.
I drag the package onto the canvas of the diagram and I get a shape to represent the package and inside the shape is the package contents.
TEST 2
I created a new EAP file (different to the one above).
I created a new catalog in MySQL.
I ran the InnoDB script against the database.
I opened my new EAP file and used the data transformation tool to upsize it to the new MySQL database.
I connect EA to the the new mysql database and repeat the steps in Test 1.
When I drag the package node from the project browser tree onto the diagram canvas I get a shape to represent the package but it doesn't list the package contents.
I would hope this is something that could be fixed with a tweak to the InnoDB MySQL script - as it works with Access database (EAP) files.
Any thoughts?
Thanks.
CA.
« Last Edit: March 25, 2009, 02:38:32 am by canderson »
« Reply #2 on: March 25, 2009, 08:33:00 am »
In the properties of each diagram on the Elements page you can check 'Package Contents'.
