Author Topic: Check In failed for package under version control  (Read 3794 times)
Marek Pribyl
« on: April 09, 2009, 08:49:58 pm »
When I'm trying to check in version controlled package it fails with error:
"Error writing XML file" and "Could not write the XML export file"
Package is checked out without errors, XMI file in SVN working copy is owned by the same user EA is run under. XMI file has read/write permissions: -rw-r--r--
EA 7.5.843 on Linux, Subversion 1.5.4
thanks for any hints
Martin Terreni
  • Sorry, I can't write
Re: Check In failed for package under version cont
« Reply #1 on: April 09, 2009, 09:59:13 pm »
I think you better try to edit it with another program and see what happens. Also, is the file under WINE folder structure? I think it better be there...
Recursion definition:
