Author Topic: EA crash after uncheck out (using mySQL and svn)  (Read 4258 times)
maite
« on: April 29, 2009, 01:29:03 am »
While trying to uncheckout a package in EA, I get the message "internal application error". I am being then asked to import the package from XMI but on that screen the import and close buttons are not available. I have no options but restart EA.
When restarting EA after the crash the package is considered as checked out.
I am the only one in my team having the issue (we have tested check out and undo checkout on our database with 7.5, 7.0 releases and everything works fine... except on my computer )
Any idea ?
Re: EA crash after uncheck out (using mySQL and sv
« Reply #1 on: April 29, 2009, 03:31:35 pm »
Do you have any problems doing an uncheckout of the xmi file outside of EA?
maite
« Reply #2 on: April 29, 2009, 04:46:14 pm »
No problem doing a revert of the xmi outside EA. I have done test with 2 different svn clients (tortoise and collabnet).
To be sure of the issue I have recreated the local svn repository, but the issue remains.
At the beginnig I worked with the release 7.1 and I had the issue so I was hoping that upgrading to 7.5 will solve the problem. Now I have upgraded to 7.5 but the issue remains.
« Reply #3 on: April 29, 2009, 07:59:31 pm »
Have you checked in your version control settings whether you use the same svn client executable as your coworkers?
Otherwise, I'm out of ideas :-/
maite
« Reply #4 on: April 29, 2009, 08:09:50 pm »
Unfortunately yes I have checked that too.
One of my coworkers has the problem too (I have obliged everybody to test the undo ckeckout with the same database than me and we found he had the issue too  :-[)
