Author Topic: Problem with exported and back imported RTF docs  (Read 3614 times)
jumbie
« on: March 05, 2009, 09:34:35 pm »
After exporting to file and back importing from this file RTF linked document does not work correctly - links are not active. :-/  The same problem with Cut and Paste of link.
« Last Edit: March 05, 2009, 09:44:11 pm by Ilja_Kraval »
Ben M.
Re: Problem with exported and back imported RTF do
« Reply #1 on: May 04, 2009, 05:35:06 pm »
You are not alone.  We experienced the same thing.  Originally our thinking was that we wanted to create the basis for the template within EA so that the yellow tags and EA styles (e.g. SSBookmark) were present, and then modify the template in Word where we had much more functionality in terms of formatting -- particularly around tables.
In the end we concluded that we could not use an external editor to author the templates, and then import them into EA.  However you can use cut-and-paste to get close, but then you may have problems trying to get EA to put the yellow tags exactly where you want them.
