Author Topic: Model document not generated  (Read 4504 times)
Martin Terreni
  • Sorry, I can't write
« on: May 05, 2009, 11:07:49 pm »
When trying to generate master document where only model document is marked (either for package or element) and nothing gets generated but the yellow remarks of EA.
What should be done to generate document model?  >:(
Am we doing something wrong, is it happening only to us?
BTW -it works for 7.1
« Last Edit: May 05, 2009, 11:31:58 pm by MartinT »
Recursion definition:
Martin Terreni
Re: Model document not generated
« Reply #1 on: May 10, 2009, 04:55:07 pm »
Answer from Sparx:
I have run over the model sent in both builds 834 and 845.
It appears it is not specific to the Model document but rather relates to the Linked Document formatting.
In 834 using a simple template like yours - just with Model Documents set on - this returns the Linked Document.
In 845 this does not return anything. On removing the first half of the Linked Document and re-saving it - 845 does return the text.
I will pass this on to be corrected.
