Author Topic: Problems with basic CSV import/export  (Read 4263 times)
drmbienvenu
« on: May 12, 2009, 12:38:38 am »
Sorry to bother folks with basic problems but...
I can't get the import/export stuff to work successfully.  Possibly there are settings for the entire project we are missing?  So, please don't assume we know anything - we are just adapting to EA.
I've tried this with both UseCase elements and Requirement elements
I defined a CSV Import/Export spec for Requirements:
Spec name:  RequiremmentsSpec.csv
Default Filename:  RequirementsExport.csv
Default Direction: Export
Preserve Hierarch : checked
Fields selected:  Name, Type, GUID, Notes
Save and exit Spec window.
Project -> Import/Export -> CSV Import/Export
Package (is blank)
Spec:  RequiremmentsSpec.csv
File: RequirementsExport.csv
Action: Export
Include Subfolders & Export Column Names are both checked.
I click Run, then ViewFile, and all I get is a spreadsheet with column names and no data.
There are requirements on the diagram - and this diagram is open while running the functions (is that the problem?)
Is the package misconfigured?  How can I tell?
Are only requirements of a certain kind exported?
Note that if the requirement is not implemented by anything (no "implements" connectors, then Model Validation returns <<name>> is unrealized, and "unrealized" isn't in any of the help files.
bioform
  • Forty-Two?
Re: Problems with basic CSV import/export
« Reply #1 on: May 12, 2009, 01:29:08 am »
Just in case: You must click on a package, and initiate the export from their... It looks like the selected package may not yhave any of the element types there, so it has nothing to export...
Time is what keeps everything from happening at once, Space is what keeps it all from happening to you. <unknown>
drmbienvenu
« Reply #2 on: May 12, 2009, 01:31:09 am »
Yep, that seems to be it.  thanks much
