Author Topic: Failing to generate document using access 2007  (Read 5731 times)
Martin Terreni
  • Sorry, I can't write
« on: May 12, 2009, 09:36:44 pm »
Whent rying to generate reposrts (even basic report)  I get error: "Datatype mismatch in criteria exception", then it fails to generate.
7.1 is the same.
Comunicated to Sparx.
Recursion definition:
Re: Failing to generate document using access 2007
« Reply #1 on: May 12, 2009, 09:53:10 pm »
Hi Martin,
What do you mean by "using" Access 2007?
Martin Terreni
« Reply #2 on: May 12, 2009, 10:00:28 pm »
Connected to Access2007 instead of EAP or DB.
« Reply #3 on: May 13, 2009, 09:01:42 am »
I don't actually know if you can. AFAIK EA does not support the new format, and perhaps not even the new (2007) engine against the old format.
« Reply #4 on: May 13, 2009, 10:22:16 am »
I've used Access 2007 to generate Access reports against both EAP files and server databases using linked tables.
I think I had the datatype mismatch early on.  Do you know which columns are causing it?
Are you connecting to an EAP or server DB?
« Last Edit: May 13, 2009, 10:24:33 am by PaoloFCantoni »
Martin Terreni
« Reply #5 on: May 15, 2009, 02:39:02 am »
I connect to it through ODBC (as to DB) this capability is available in EA since 7.1.
Martin Terreni
« Reply #6 on: May 17, 2009, 03:09:32 pm »
Thanks for the report.
This issue has been logged with ID 09052635.
We hope to have in resolved for the next release.
