Author Topic: Importing 500 tables from a list of 70k Oracle tab  (Read 5310 times)
Stefan S.
« on: June 11, 2009, 08:32:12 pm »
In Enterprise Architect 7.5, I tried importing 500 of our SAP tables in our Oracle database, and had some problems. I got the ODBC driver to connect to the Oracle DB, and also to retrieve the list of the 70000+ tables (for the sapr3 scheme), but when I select the 500 tables I am actually interested in, the dialog hangs upon a click on the OK button and does not proceed.
Same applies if I only select a single entry out of the 70000.
Is there a workaround?
kosh.iii
Re: Importing 500 tables from a list of 70k Oracle
« Reply #1 on: June 12, 2009, 11:20:49 pm »
As a workaround you could create a new database user which only "sees" the tables you want to import and then use this user for the ODBC connect. I assume the dialog should be able to deal with these better than with a list of 70.000 tables.
