Author Topic: Is there a trick to Import DB schema from ODBC So  (Read 3314 times)
Jacko
« on: June 16, 2009, 06:34:42 am »
I'm trying to go against an Oracle DB using the Oracle in Oracle Client home Driver ::) - which I think uses the tnsnames file but I can't get it to work. Any tips?
Re: Is there a trick to Import DB schema from ODBC
« Reply #1 on: June 16, 2009, 09:05:18 pm »
Can you create a Windows DSN to connect to Oracle? I mean from outside EA. If so, from EA just reference that DSN. Note that EA might only handle a system or user DSN (I do not remember which, or even if this limitation applies at all) so you may have to try both variants.
