Author Topic: Reading ClientEnd taggedvalues throws an exception  (Read 3435 times)
ErnstNaezer
« on: January 18, 2006, 06:56:55 am »
Hello pll,
I'm trying to read the TaggedValues of the ClientEnd and the SupplierEnd of an association (connector) object.
But I get the following error:
Unable to cast COM object of type 'System.__ComObject' to interface type 'EA.ConnectorTag'. This operation failed because the QueryInterface call on the COM component for the interface with IID '{AB28E995-ED5A-4ECE-9576-221B0239A44A}' failed due to the following error: No such interface supported (Exception from HRESULT: 0x80004002 (E_NOINTERFACE)).
Casting this object to other Tag types doens't seem to help very much. Does anybody know which to which Type I should use to acces the tag?
thanks!
Ernst Naezer
The Netherlands.
I'm using version 2.10.238.1 of the Interop.EA.dll
p.s. Reading the TaggedValues of the connector and other types works like a charm...
« Last Edit: January 19, 2006, 12:38:44 am by ErnstNaezer »
ErnstNaezer
Re: Reading ClientEnd taggedvalues throws an excep
« Reply #1 on: January 23, 2006, 02:51:14 am »
Fixed! Turned out I had to cast this TaggedValue to a RoleTag class..  :-/
