Author Topic: PHP Code generation  (Read 3815 times)
chrisg
PHP Code generation
« on: June 19, 2009, 07:32:31 pm »
Hi  I generate source code from EA to PHP and use Eclipse as editor. On reverse engineering, EA destruct the return parameter of a method and use var.
Helpfile -> "Methods returning a reference are generated by setting the Return Type to var*
In Eclipse, a function comment "@return Name_Of_Type" (javadoc comment) allow an IntelliSense function. If the reverse engineering engine use this comment instead of the simple "var" keeps the return parameter in the UML Model!
Or is there a workaround/misunderstanding ?
LastDragon
