Author Topic: RTF Generator and Master Documents  (Read 5083 times)
cweng
« on: July 02, 2009, 06:44:59 pm »
I am having two problems with master documents.
1. I can't get first page header/footer to work. It always prints the rest of document header/footer on the first page.
2. The formatting applied to the table of contents is wrong.
I have tried with the template that has the first page and table of content linked directly to the master document element and tried with a separate model element for the document first page and TOC. The results are the same.
If I generate a document just using the covering pages model document, both the header/footer and the TOC are correct.
Any ideas?
Graham_Moir
Re: RTF Generator and Master Documents
« Reply #1 on: July 09, 2009, 10:29:13 pm »
I'm experiencing the same issue with the Table of Contents - seems to have a complete mind of its own no matter what you do !
I haven't tried the first page header/footer so can't comment on that one.
Dermot
« Reply #2 on: July 10, 2009, 11:40:15 am »
There is a correction for Master Documents not showing the First Page heade/Footer - this should be available in the next build - 846
