Author Topic: Loss of tag values on Flow Ports  (Read 4214 times)
dave keeling
« on: December 10, 2008, 08:27:16 pm »
I am using EA build 733 with the SysML add-in. I have noticed a problem with the tagged values being lost from flowports added to blocks in block definition and internal block diagrams. When the flow port is added the display is correct (default direction inout and isConjugated set to false) however when the port is moved I have found that the tagged values are lost from the port causing the graphic to be lost within the port. It is possible to recover the graphic by manually adding the tagged values to the port.
bash
Re: Loss of tag values on Flow Ports
« Reply #1 on: July 15, 2009, 02:56:16 am »
I have also experienced this problem with the newer builds.  Have you found any other workarounds except for the manual re-assignment?
« Reply #2 on: July 15, 2009, 07:44:53 am »
By "newer" do you mean builds since EA 7.5 came out?
dave keeling
« Reply #3 on: July 15, 2009, 05:48:27 pm »
I have tried on the latest build and the problem still seems to exist. Initially I had been usihng the MDG plu-in for SysML where the problem had been experienced. Version 7.5 (build 845) now supports SysML in the core package however the problems with blocks and embedded ports seem to be carried into this verison.
