Author Topic: Autonum in Column Properties inaccessible  (Read 6171 times)
Max32
« on: June 08, 2009, 07:57:58 pm »
Hi!
Autonum in Column Properties inaccessible (grayed and don't expand):
but in help is said that this feature must work:
This feature work in the version 7.0.x, but inaccessible in 7.5.xxx  :'(
Re: Autonum in Column Properties inaccessible
« Reply #1 on: June 09, 2009, 06:03:55 am »
There are a few places in EA where you need to first save an attribute - a column is a stereotyped attribute - before you can access the extended properties dialog(s). Try saving your column first, with minimal information. Then see if the button and dialog become enabled.
Max32
« Reply #2 on: June 09, 2009, 06:29:14 am »
Of course attribute is saved! Button with caption "Column Properties..." is enabled. But! When i push this button "Database Columns Properties" window it is opened and TreeView node with caption "Column Properties" (see number 3 in the picture) is not expand. Node collapsed, grayed and don't expand. Try to do themselves and make sure.
« Reply #3 on: June 10, 2009, 09:37:16 pm »
Make sure that the table has a DBMS set in the drop-down. Sometimes EA does not set a database, and some settings are disabled. This also shows up when you generate DDL, as many statements are missing or have strange syntax.
Max32
« Reply #4 on: June 12, 2009, 04:23:49 am »
I understood!!!  8-)
This feature DON'T WORK on next type of database:
- Informix
- Ingres
- InterBase
- MSAccess
- Sybase
- Sybase ASE
and very well work on:
- MySQL
- Oracle
- PostgreSQL
- SQL Server 2000
- SQL Server 2005
- SQLServer7
So, tell me please is this a bug? and i can fix it self or not?
« Reply #5 on: June 12, 2009, 10:18:24 pm »
And it should work in SQL Server 2008 if you can update your reference data in EA 7.5.
As for the DBMS engines it will not work with, I suggest you send the question to Sparx Support, perhaps just using their email address here.
Please post back to let us know what the answer is.
Max32
« Reply #6 on: July 18, 2009, 07:29:25 am »
Yes! I have received the answer:
"...we will adjust the AutoNum options for a future release..."
and the most important part of the message:
"...In the meantime, there is a workaround. Highlight the column in question, and add the following tag in the tagged values window...
Tag: property
Value: AutoNum=1;StartNum=1;Increment=1;"
I have checked up is works!  :)
« Reply #7 on: July 19, 2009, 02:49:02 am »
Thanks for posting back with the reply. That's a valuable workaround.
