Author Topic: The Undo button has a Save Icon  (Read 5420 times)
Tad Anderson
  • The more I learn the less I know....
« on: July 24, 2009, 03:21:27 am »
If you notice you are having to do a lot of things over that you thought you already did, like I have been doing all morning…..
It seems that in the latest release (Build 846), they mixed up the save and the undo icon.
« Last Edit: July 24, 2009, 03:22:41 am by tadanderson »
Paul Lotz
Re: The Undo button has a Save Icon
« Reply #1 on: July 24, 2009, 04:58:47 am »
I (and others before me) reported this to EA.  Sparx support said this is logged as a bug and noted:
"You should be able to "reset" to the correct icon by using the "Tools | Customize | Toolbars | Reset All" option or select only "Default Tools"
and use the "Reset" option. (Please note, this will reset any toolbox customizations you may have made)."
The proposed solution worked for me!
Paul
Tad Anderson
« Reply #2 on: July 24, 2009, 06:07:53 am »
Worked for me too.  :)
Thanks for the info...
« Last Edit: July 24, 2009, 06:08:10 am by tadanderson »
« Reply #3 on: July 24, 2009, 08:20:23 am »
An additional note that build 847 will do this reset for you.
« Reply #4 on: July 24, 2009, 10:14:07 pm »
In the meantime remember that a reset causes EA to lose many (perhaps all) of your UI customizations.
