Author Topic: Enum Tagged Value: default value not shown in RTF  (Read 3878 times)
MatthiasH
« on: August 25, 2009, 06:35:29 pm »
I have created a new profile for Requirements, so I have some pre-defined Tagged Values present in all my Requirement elements.
One of the Tagged Values is an enum, having a default value.
Actually, I followed 99% of an example provided in the documentation.
When adding a new Requirement, this Tagged Value has the default value until some other value was manually assigned.
When creating the RTF report, no value is shown for this particular Tagged Value for all Requirements having still their default value.
After manually assigning a value - even the default value - the value is shown correctly in the RTF report.
It seems that internally the default value is not assigned, leading to having in fact an "empty" Tagged Value.
(EA 7.5 Prof. 847)
Matthias
Re: Enum Tagged Value: default value not shown in
« Reply #1 on: August 25, 2009, 11:10:09 pm »
Have you checked this in Build 848? [Just in case; there were only a small number of tweaks included in that build.]
If (or when) you check, and if the problem persists, please report it to Sparx in a bug report. [...by following the Report a Bug link near the bottom of any forum page.]
« Last Edit: August 25, 2009, 11:10:35 pm by Midnight »
MatthiasH
« Reply #2 on: August 26, 2009, 01:08:44 am »
... just for you  ;) I checked with 848: identical behaviour.
Bug report will be filed in a minute.
Matthias
