Author Topic: Using issues and reporting them against elements  (Read 3623 times)
pierreraby
« on: August 26, 2009, 05:41:48 am »
Hi everyone. I have created an Issues model. In a separate use case model, i am matching the requirements (from a third model) and the issues to use cases and run the RTF report to demonstrate coverage of requirements and issues in the use case model (which represents the to be solution). The issues never come out as the issues associated to the use case. The RTF template does have the ElemIssue.Issue constructs in the template. Is there a specific connector to use (trace, realize, ???) or am i missing something. Thanks for your help
pierreraby
Re: Using issues and reporting them against elemen
« Reply #1 on: August 26, 2009, 05:54:07 am »
You can forget my post. I found the answer. Unfortunately, the ElementIssue.Issue construct in the RTG generator only deals with maintenance issues reported against an element. It does not seem to deal with the Issue object that ressembles the requirement object in the common area in many toolbloxes even if you connect it to an element.    Dommage.
