Author Topic: Problem with default RTF template  (Read 3045 times)
Emilio
« on: September 01, 2009, 06:24:59 pm »
I am generating a technical document using the template and noticed that all the time the table that is generated for the element's relationships (realization, association, aggregation, etc.) are broken:
Connections
Connector      Source      Target      Notes
Dependency  File Creation
Source -> Destination
            target > {ConnTarget.Scope} {ConnTarget.Role} {ConnTarget.RoleNote}
element >
{Element.Name}
< element
< target
constraint >
{ConnConstraint.Type}  {{ConnConstraint.Name}}
< constraint
Realisation
element >
{Element.Name}
< element
< target
constraint >
< constraint
element >
{Element.Name}
< element
< target
constraint >
< constraint
As you can see the placemarkers are not replaced and some XML tags are broken into two.
Dermot
Re: Problem with default RTF template
« Reply #1 on: September 02, 2009, 04:49:50 pm »
Please submit this via the support email along with an export of the template.
