Author Topic: PseudoStates don't respond to stereotype  (Read 3564 times)
« on: September 04, 2009, 01:59:11 pm »
If you put a stereotype on a pseudostate (StateNode) it won't respond to shape scripts or to any other setting within the Setting|UML... dialog.
They don't even auto-select within the list as other stereotyped elements do.
While Sparx is fixing 09083313 - StateNodes - DON'T respond to FILL Colour, they might as well fix this...
Reported,
Re: PseudoStates don't respond to stereotype
« Reply #1 on: September 04, 2009, 03:31:37 pm »
The problem appears to be caused by the fact that pseudostate (the value placed in the "Base Class" field of the Settings|UML... dialog (by EA itself!) is not a valid value.
However, if you change the Base Class to <all>, the pseudostate WILL respond...
EAUI strikes again!
Should be an easy fix...
« Last Edit: September 04, 2009, 03:32:40 pm by PaoloFCantoni »
