Author Topic: Problem modeling a singleton class  (Read 4166 times)
EricP
« on: September 04, 2009, 04:00:14 am »
Ran into another problem in trying to model a singleton design pattern in EA.
Consider the following singleton class and its implementation:
In the header (.H) file:
class Log
  public:
    static Log* Inst(char* filename);
    void Logging(string message);
    void Initialize();
    ~Log();
  protected:
    Log(); // constructor
  private:
    static Log* pInstance;
In the .CPP file:
Log* Log::pInstance = NULL;  // <<< note this line
Log* Log::Inst(char* filename)
  if(pInstance == NULL)
    pInstance = new Log(filename);
  return pInstance;
Log::Log()   // private constructor
  // do whatever the constructor needs to do...
Log::~Log()
  delete pInstance;
  pInstance = NULL;
Note that pInstance needs to get declared and initialized outside of any method.  My problem is trying to figure out a way to model this with EA such that when I generate code, the "Log* Log::pInstance = NULL;" gets generated along with the rest of the code... otherwise I get compile errors and have to remember where all those lines of code need to go.
EA version is 7.1.833; if this kind of code generation is provided for in 7.5 let me know and I'll upgrade.
Re: Problem modeling a singleton class
« Reply #1 on: September 04, 2009, 05:06:19 pm »
I don't really know much abou the EA code generation, but I have modelled the singleton pattern before.
I think you should be creating a static attribute pInstance of type Log with a default value of NULL.
In theory that should result in the code you showed (if I understood your problem/code correctly)
