Author Topic: Generating BPEL from BPMN diagram?  (Read 5305 times)
Tarja
« on: September 01, 2009, 11:55:54 pm »
Hi!
I noticed that EA 7.5 makes it possible to generate BPEL. But how?
If I have a BPMN process diagram and of course some attributes defined for tasks (in the Tagged Values), how to generate the code?
And which attributes are mandatory to be defined?
Tried to find some guidance from help but could not find any.
Best regards, Tarja
Re: Generating BPEL from BPMN diagram?
« Reply #1 on: September 02, 2009, 07:11:12 am »
Hi Tarja,
First check which edition of EA you are using. AFAIK you need either the Business & Software Engineering Edition or the Ultimate Edition of EA to work with BPEL. I do not believe that either edition (yet) imports BPEL. I am not sure about that, so you should confirm this on your own.
My guess is that whatever options EA provides for BPEL import might not appear (at all) unless you have one of the above editions.
See the EA edition comparison page on the Sparx site for more information.
RoyC
  • Read The Help!
« Reply #2 on: September 02, 2009, 10:04:50 am »
If you do have the correct edition, see the following Help topic:
http://sparxsystems.com/uml_tool_guide/extending_uml/bpel.html
This contains a small hierarchy of 12 topics on creating BPEL models.
Best Regards, Roy
Tarja
« Reply #3 on: September 08, 2009, 05:46:06 pm »
Hi!
I have the 7.5.843 Corporate Edition and from the comparison table I saw that code generation is not supported. I have to think about whether to upgrade...
Thanks, RoyC, from the link!
Regards, Tarja
« Reply #4 on: September 08, 2009, 06:29:02 pm »
Hi!
Regards, Tarja
I would encourage you to download the trial version and check it out...
Remember you only need 1 licence to generate.
Let us know how you go if you decide to try it...   :)
