Author Topic: fixedAspectRatio="false" - Spurious Error Message  (Read 4250 times)
« on: September 11, 2009, 04:43:10 pm »
Setting:
fixedAspectRatio="false";
 in a shape script generates the  spurious error message:
Error: Invalid value for orientation. Acceptable values are: "nw", "n", "ne", "e", "se", "s", "sw", "w", "nw",  and "center"'false
Reported,
Re: fixedAspectRatio="false" - Spurious Error Mess
« Reply #1 on: September 11, 2009, 09:00:52 pm »
I don't agree.
The message is far from spurious, there's a real error around here somewhere.
As to the text displayed, this might be long-awaited real proof [I couldn't resist] that not everyone prefers Clayton's.
« Reply #2 on: September 11, 2009, 11:07:21 pm »
I don't agree.
Well, if I set the value to true, the error goes away.  And even with the error message displayed the shape script works EXACTLY as I expected.
Since there's NO indication of which line is being complained about and if you remove the line completely, the error goes away.  I have no evidence that the message isn't spurious.
I discovered the "spuriousness" of the error when I had a working shapescript and accidentally pasted the line (having thought I copied some other code - you know how sometimes a "Copy" doesn't "take").
Anyway, I'll wait Sparx's response.
« Reply #3 on: September 14, 2009, 03:52:09 pm »
Sparx have acknowledged the spurious message, but they point out that the documentation:
fixedAspectRatio
Set to true to fix the aspect ratio. Do not use if you do not want to fix the aspect ratio.
means that:  fixedAspectRatio="false" is actually invalid syntax.  The inverse of  fixedAspectRatio="true" is the absence of the  fixedAspectRatio entry.
My reply is that this form of grammar is confusing.  By all means let the absence of  fixedAspectRatio imply  fixedAspectRatio="false".  But that should NOT make  fixedAspectRatio="false" invalid syntax.
Thoughts?
« Last Edit: September 15, 2009, 11:27:53 am by PaoloFCantoni »
« Reply #4 on: September 15, 2009, 09:37:34 am »
Unary? Oolean? Single-valued logic?
Or perhaps an unalterable truth. The possibilities sound exciting.
