Author Topic: Not able to create <<enumeration>> table and links  (Read 3545 times)
NPRADEEP
« on: September 18, 2009, 02:21:09 pm »
We are evaluating the EA – Corporate edition and planning to buy in future.
I am trying work on our .eap project file, but some issues we found, please clarify on these.
1. Not able to create <<enumeration>> table and its links.
a)      We have a package called customer, in which some tables and <<enumeration>> are there,
 when I try to create table using "Transform Current Package" and selected "DDL" and "include child packages option"
       and clicked do transform.
 b) Then created “DLL.sql” using "Code engineering" -> "Generate DDL", here also I have selected "Include all child packages".
c) But in “dll.sql” not able to find any <<enumeration>> tables.
Please check the following sample, i can see customerkind data type,
but there is no Customerkind table or object found in “DDL.sql” file.
            (We are using  => MYSQL database)
e.g.
CREATE TABLE Customer
      kind CustomerKind NULL,
      pucNumber VARCHAR(50) NULL,
      specialNeed VARCHAR(50) NULL,
      status Status NULL,
      vip BIT NULL,
      customerID INTEGER NOT NULL,
      PRIMARY KEY (customerID),
      KEY (customerID)
2. Found Constraint names duplicate in “ddl.Sql” file. (CustomerAgreement )
eg.
ALTER TABLE JoinCustomerAgreementToEquipment ADD CONSTRAINT CustomerAgreement       FOREIGN KEY (customerAgreementID) REFERENCES CustomerAgreement (customerAgreementID);
ALTER TABLE JoinCustomerAgreementToPricingStructure ADD CONSTRAINT PricingStructure fOREIGN KEY (pricingStructureID) REFERENCES PricingStructure (pricingStructureID);
ALTER TABLE JoinCustomerAgreementToPricingStructure ADD CONSTRAINT CustomerAgreement  FOREIGN KEY (customerAgreementID) REFERENCES CustomerAgreement (customerAgreementID);
ALTER TABLE JoinCustomerAgreementToServiceLocation ADD CONSTRAINT ServiceLocation FOREIGN KEY (serviceLocationID) REFERENCES ServiceLocation (serviceLocationID);
ALTER TABLE JoinCustomerAgreementToServiceLocation ADD CONSTRAINT CustomerAgreement FOREIGN KEY (customerAgreementID) REFERENCES CustomerAgreement (customerAgreementID);
Please let me know how to handle ths problem, as we are planning to use ths tool for current and future projects.
