Author Topic: MTS Wizard should be "Sticky"  (Read 17785 times)
« on: October 01, 2009, 04:54:15 pm »
The MTS generation wizard should be more "sticky" - at least on a per session basis.
It should remember if you are using an MTS file or not.  If you are, it should remember the last one you used (ESPECIALLY if there's ONLY one specified!)
Lastly, as I use the Wizard, I find I'm 99% of the time pressing Next>Next>Next>Finish.  Most wizards of this type have an early Finish button - enabled after the first run of the wizard - once the values are set up.
As I'm developing the MTS technology, I sometimes go through this process several times an hour.  The clicks (and time) add up.
Reported,
« Last Edit: October 01, 2009, 04:56:18 pm by PaoloFCantoni »
