Author Topic: JAVA Code Generation Problem - Comments  (Read 5250 times)
moacsjr
« on: August 12, 2005, 04:57:04 am »
I'm still having problems with JAVA code generation.
Create a class then put some attributes on it.
Add some comments for each attributes.
Now try to generate this class. [ctrl + g]
Please note that the option "Allways synchronize with existing flies" needs to be selected.
Ok now you have successfull generated the JAVA class.
Now generate it again, and you will have duplicated comments.
package br.syndeo.dms.domain.servico;
* @author Marcelo Dutra
* @version 1.0
* @created 12-ago-2005 08:36:14
public class Defeito {
* É o código que identifica o defeito
private int codDefeito;
* É a descrição do defeito
private String dscDefeito;
* Indica se o defeito
private boolean trinca;
public Defeito(){
public int getCodDefeito(){
return codDefeito;
public String getDscDefeito(){
return dscDefeito;
public boolean isTrinca(){
return trinca;
* @param newVal
* @param newVal
public void setCodDefeito(int newVal){
codDefeito = newVal;
* @param newVal
* @param newVal
public void setDscDefeito(String newVal){
dscDefeito = newVal;
* @param newVal
* @param newVal
public void setTrinca(boolean newVal){
trinca = newVal;
bvyn
Re: JAVA Code Generation Problem - Comments
« Reply #1 on: February 07, 2006, 08:36:29 am »
I've been experiencing the same problem with duplicate comments when generating code for C++.  Did you ever find a resolution to the problem?
« Reply #2 on: February 07, 2006, 01:04:16 pm »
From memory there was a problem that matched this description fixed a few builds back.
If it's the problem I think it is then you have two options.
  • Upgrade to the latest version of EA.  ;)
  • Open the options (Tools | Options) to the Source Code Engineering (used to be Generation) page and check the Reverse checkbox in the Comments group.
Hope that helps.
bvyn
« Reply #3 on: February 07, 2006, 01:58:23 pm »
Just so you know, I am currently using Build 785 (almost the latest) and the Reverse checkbox in the Comments group is checked.  The problem is not consistent either.  In some cases duplicate comments are generated, and in others, everything is Ok.
« Reply #4 on: February 07, 2006, 05:36:33 pm »
Well, in that case it's not the same problem and I haven't seen it.
It probably has something to do with some combination of options and possibly modified templates, but I have no idea which options might be doing it.  If you find anything then let me know.
