Author Topic: SysML Model Report problem  (Read 3801 times)
Dave.B
« on: October 14, 2009, 01:47:51 am »
I'm trying to produce a report for a package that contains a SysML model comprising of Block Definition Diagrams (BDD) and block elements and Internal Block Diagrams (IBD) for the composite block elements. A simple diagrams only report that contains both the BDDs and IBDs is possible. But I've found a problem when trying to also document the blocks and their composite parts.
When I have a report template that has the "diagrams" section it is possible to have the report generator document all the elements in each diagram by adding an "elements" sub-section to the diagram. (Although, I have also found that you have to set the "document elements" option on the diagram properties for it to work.) This is great for documenting the BDDs.
Conversely, when I have a report template that has an "elements section" it is possible to have the report generator output all the diagrams for each element by adding a "diagrams" sub-section to the element. It is also possible have the report generator document each part by adding an "embedded elements" sub-section. This is great for documenting the IBDs.
However, when I put both of these together in one report template, the "elements" sub-section of the "diagrams" section no longer emits anything to the report.
Is this a bug or by design?
Dave B.
PS EA version 7.5.849
