Author Topic: Add branch do version control  (Read 5123 times)
Henrique Narciso
« on: October 27, 2009, 04:50:00 am »
After I imported a model from another project, I wanted to add it to version control.
The issue her is that it manages to say that a specific file already exists.
How can I go around this?
I cannot go to TFS and delete the files.
How can I know without a dought that I'm deleting the correct files, even if I manage to get a list of them?
Re: Add branch do version control
« Reply #1 on: October 27, 2009, 07:52:06 pm »
You can always add each package manually to version control.
That allows you to specify the name of the xmi file that is being controlled.
Or use a different package in TFS for your version controlled files.
Henrique Narciso
« Reply #2 on: October 27, 2009, 09:05:20 pm »
The tree Im adding to version Control has over 40 packages. Don't Know the best way to go throught this.
« Reply #3 on: October 27, 2009, 09:06:32 pm »
In any case, if you are adding them manually you alwas have to work bottom up.
Henrique Narciso
« Reply #4 on: October 27, 2009, 09:50:22 pm »
yeap, is there any way I can get a list of files that are linked to the tree I'm inserting?
