Author Topic: importing DAta model , description errors  (Read 3999 times)
Henrique Narciso
« on: October 28, 2009, 10:03:00 pm »
When using de Import DB Schema from ODBC option the column comments are not updated properly.
We are using a SQL2005 database the DSN was created with the native SQL2005 driver.
All table and column comments are in the MS_Description extended property. While creating or synchronizing a data model some tables and columns aren´t updated properly.
what we’ve found so far is that if the table or column has more than one extended property, the notes in EA are updated with the value from the last extended property.
any workarround?
Anyone with the same behaviour?
version 848
hd
Re: importing DAta model , description errors
« Reply #1 on: October 29, 2009, 09:38:49 am »
I suggest you report this as a bug using the Report a Bug link below.
