Author Topic: Problem with MDG Link for Eclipse  (Read 4433 times)
Goarnisson
« on: April 18, 2005, 07:26:02 am »
First I use EA and generate Java code from the modeling class. I use an IDE to open the Java class and build projetc. Everything were ok.
As I use Eclipse, I try MDG Link for Eclipse with EA.
So I associate an Eclipse project to a modeling project.
And then I can generate ou reverse code.
But when a modeling class and a class in Eclipse are associate, I don't succeed in regenerate code. The file seems to be lock. However I try every thing  ???
- to use Advance option "Overwrite File",
- the file is not read only
It's surprising because if I modify code, I can make reverse and get back the code modification but not in the way Model->Code (When I did, EA believe it's ok because I have "Generation completed !"
The only way I find to reproduce code is to suppress file.  :-/ Not a very good way, u know !
Already have this problem ? Is there a way to succeed?
Guillaume G.
Etienne_Martin
Re: Problem with MDG Link for Eclipse
« Reply #1 on: January 20, 2006, 08:09:53 am »
I have the same problem and I'm seaching for solution.  Give me some news if you find something and I'll do the same.
Barry_Pearce
« Reply #2 on: February 16, 2006, 08:47:49 am »
And me too....i also have the same problem...In 2 days ive tried a new setup with EA ( been using it for several years now since the 3.60 days)...but trying both subversion controlled pakages and the MDG link for eclipse both fail....I have to ask the question....is anyone using any of these features successfully?
Eric Gustafson
« Reply #3 on: February 18, 2006, 05:07:09 pm »
I also have started having this problem.  I took a project (EA and Eclipse) that were working with forward engineering a few weeks ago (2-3) and all of a sudden the forward engineering (code gen) has does not modify existing Java source files.  I can, however generate a new .java file, but after the initial generation into the Eclipse project no further forward code generations have effect.  Reverse engineering works just fine.
Caveat:  While I haven't adjusted my EA configuration, I did add and upgrade a number of non-EA Eclipse plug-ins.
For the record:
 EA v6.0.781
 MDG Link 1.0.19
 Eclipse Version: 3.1.1 - Build id: M20050929-0840
I'm putting a ticket directly into Sparx next - will report back.
