Author Topic: Problem with DTD  (Read 3839 times)
pebran
Problem with DTD
« on: November 25, 2009, 09:20:39 pm »
Trying to import a valid xsd that contains a DOCTYPE gives me this error message:
“The element ‘xsd:schema’ is used but not declared in the DTD/Schema.”
The xsd starts with :
<?xml version="1.0"?>
<!DOCTYPE xsd:schema [ ... declarations in here ...]
and the root element is defined as:
<xsd:schema xmlns:xsd="http://www.w3.org/2001/XMLSchema">
The schema validates OK with XML Spy so why cant I import this to EA?
Peter
pebran
Re: Problem with DTD
« Reply #1 on: November 26, 2009, 11:25:14 pm »
And let me add to the above:
Is it the use of DTD in the schema that is done wrongly - though it is validated OK in XML Spy - or is it EA that is in error?
It would be nice if someone from Sparx could comment on this.
/Peter
« Reply #2 on: November 26, 2009, 11:49:55 pm »
Peter,
This is a user forum (although the Sparxians often help out as well), if you want a reply from Sparx you better send a support request their way.
