Author Topic: Windows file names in templates misinterpreted  (Read 6531 times)
Oliver F.
    • Karl Storz homepage
« on: November 28, 2009, 01:25:23 am »
Filed a new bug:
A Windows like file name string which is defined in a template is always translated into something with a control character.
Eg.: "c:\temp\test.sql" is translated into "c:<tab>emp\<tab>est.sql"
Create a code generation template, define a variable $filename with the value "c:\temp\test.sql", assign it to a data field and start code generation.
In the log file the variable is transformed into a variable with tabs instead of \t characters.
Oliver
Re: Windows file names in templates misinterpreted
« Reply #1 on: November 28, 2009, 09:51:35 am »
Hi Oliver,
The temporary work around (which may become permanent) should be to 'escape' the slashes.  Ea is interpreting the \t as the <tab> specifier.
Changing to c:\\temp should fix it...
P.S. Sorry if "teaching grandmother to suck eggs".  ;)
Oliver F.
« Reply #2 on: December 01, 2009, 12:07:48 am »
Of course I tried this, too. Unfortunately it does not work at all  :o
Thanks for your input anyway.
Oliver
« Reply #3 on: December 01, 2009, 12:40:59 am »
Oliver
I guessed you would have.
I suppose this make EA inconsistently incorrect in this case...  ;)
(since \t is interpreted as <tab> but \\ in not interpreted as "\")
Oliver F.
« Reply #4 on: December 01, 2009, 01:04:12 am »
To get around the issue I found out how to use the local path dialog and this works much better anyway so consider the issue as minor :)
Oliver
