Author Topic: code engineering Actionscript 3: parser block  (Read 3559 times)
maddec
« on: December 10, 2009, 05:08:58 am »
Hi there,
When I import an as3 class containing a RegExp literal:
var pattern2:RegExp = /test-\d/i;
the parser block and report an error: There was an error parsing ../MyClass.as on line 77.  Unexpected symbol: /
I know that I could use the new operator instead:
var pattern1:RegExp = new RegExp("test-\\d", "i");
But in some cases this is really boring/impossible to modify this in eahc class manually.
Thank you in advanceto fix this problem.
Best regards.
maddec
