Author Topic: Too hard to delete Transform Templates  (Read 3520 times)
« on: December 17, 2009, 06:33:09 pm »
The creation of a Transformation or Code template shouldn't require the changing/saving of one of the subsidiary macro templates.  I may want a default template under another name.
Similarly the deletion of a template should NOT require the explicit deletion of every changed subsidiary macro.
When you're creating new transforms and testing changes, you often want to quickly create/delete temporary templates to allow you to "Compare and Contrast".
What Use Case does the current behaviour support?
Reported,
