Author Topic: Connector/association type wrongly reckonized !  (Read 6402 times)
allnamesaretaken
« on: February 06, 2010, 07:32:21 am »
Hi all,
i have one class which implements one interface. After I import with Source Code Engineering to EA instead of "Realisation" link I am getting "generalitarion", why ?
Also I never getting in my UML Class diagram connector Composition or Aggregation type although I have it in C# code... bug  or  what ?
Thanks!
br,
milan.
Re: Connector/association type wrongly reckonized
« Reply #1 on: February 08, 2010, 05:38:18 am »
Milan,
It might be useful to post the code that you are reverse engineering and tell us why you expect a certain result in EA.
For the realization/generalization that might be trivial, but for the composition/aggregation issue it isn't.
allnamesaretaken
« Reply #2 on: February 08, 2010, 10:07:41 pm »
If someone need example it is given here:
http://www.sparxsystems.com/cgi-bin/yabb/YaBB.cgi?num=1265266117
but I believe that anyone started to work with source code engineering came pretty fast to the same connclusions:
just "association" connection type is reckognized by EA.
Can I get here some official statement that in version EA 7.5 uml from code does not work ?
br,
Milan.
« Reply #3 on: February 08, 2010, 10:56:13 pm »
Milan,
For "official statements" this is the wrong place.
This is primarily a user forum, and although the Sparxians regularly visit the forum and reply to questions, I'm pretty sure this isn't an official channel by any means.
« Reply #4 on: February 09, 2010, 08:47:58 am »
I don't recall seeing any issue where generalizations are created instead of realizations, but can imagine that if EA is thinking that the parent is a class instead of an interface it could occur.
As for aggregations, EA does not import them and I do not consider that a major limitation.
