Author Topic: Window "New Diagram" always POP UP.  (Read 8705 times)
bkwasniewski
« on: January 29, 2010, 10:39:59 pm »
When I move (change position) anything on any diagram (for example class element on class diagram) window "New Diagram" pops up. It's really annoying. I have windows 7, and EA 7.5.850 trial version downloaded today. I've installed that on Windows XP, and there that problem doesn't occur.
Is there somebody that have the same strange issue???
PLEASE HELP THIS DRIVES ME CRAZY!!!
AND EA IS THE BEST.
bkwasniewski
Re: Window "New Diagram" always POP UP.
« Reply #1 on: January 29, 2010, 11:00:00 pm »
Not only when moving elements, but also when you want resize something.
This bug occurs when you release left mouse button after you move mouse.
WHY OH WHY.
« Reply #2 on: January 29, 2010, 11:02:10 pm »
That is weird indeed.
You better report it to Sparx using the link on the bottom of the page.
mrf
« Reply #3 on: February 01, 2010, 08:58:33 am »
Yeah a bug report would be appreciated thanks. I develop and run EA on Windows 7 here and it works as it should.
Can you please let us know if you have any addins etc installed as well.
Best Regards,
Michael
« Reply #4 on: February 01, 2010, 01:52:03 pm »
I did see a similar issue someone had once.  It ended up being related to another program that was installed.  Unfortunately I can't think of what the offending program was.
son-of-sargasso
« Reply #5 on: February 01, 2010, 10:08:20 pm »
Girlfriend 2.0 vs Wife 1.0?
hehehehe
sorry, it's an oldy but I couldn't resist
b
bkwasniewski
« Reply #6 on: February 02, 2010, 01:58:06 am »
I think is not related only to Windows 7, because i tried it on my second computer with Windows 7, that my wife use - there is almost no other programs except Windows 7 and Office, on my machine, witch is Lenovo IdeaPad Y550, i have a lots of stuff... now i thing i'm going to check it more deeply, if i discover the reason i will let you know... thanks for reps...
bkwasniewski
« Reply #7 on: February 11, 2010, 11:11:14 am »
I spent some time, to uninstall some unnesesary programs, i check registry, scan for viruses, but the problem still is the same, and it is imposible to work with than annoing pop up "new diagram" every time I release left mouse button. And 60 minutes ago i made mad clicking dragging everywhere everything in application, it helps - the chaos fix it, but i couldnt redo the same thing again, and i discovered - YOU NEED TO HIGHLIGHT ANYTHING in PROJECT BROWSER for example "Model" and you do that by pressing left button on "Model" and releaasing the button on non-clickable area on tool bar. AND it works, of course it is a baypass. I'm going to show you some screens if you don't believe... if you want to... ok... i dont know why it happens i think lenovo and my skills to makes everything hard...
« Reply #8 on: February 11, 2010, 11:26:01 am »
Just a thought - I have no idea if this will help or not - but the shortcut for the New Diagram dialog is Ctrl+Insert and some other application may have redefined some other event to send a Ctrl+Insert. So go to Tools>Customize, open the Keyboard tab, set Category to Project, set Command to Add Diagram, select Ctrl+Insert and press Remove. Let us know if that helps.
bkwasniewski
« Reply #9 on: February 11, 2010, 11:43:23 am »
That was a good shot. You are awesome. For my excuse, I was looking there but i couldnt find a shortcut that open new diagram (to many lists and dialog boxes) - it could be a babylon dictionary as i think there is a similar shortcut to open a word serch, but i may be wrong...
THANK YOU VERY MUCH.
bkwasniewski
« Reply #10 on: February 11, 2010, 11:52:51 am »
I assign again this shortcut, the behavior appear again, but i disable/close babylon dictionary and we found a 'bad boy" hehe...
I reassign to another shortcut ctrl+alt+shift+i and it is ok thith that shortcut.
Something is wrong with babylon dict., because "Click <Ctrl + Right Mouse Button> on any word" - it is not left button mouse and i dont press ctrl. maybe they messup someyhing with messages what ever thanks ones again
