Author Topic: Error launching EA  (Read 4173 times)
Chris Perrin
Error launching EA
« on: February 12, 2010, 01:45:53 pm »
Hi All,
When I launch EA I get the following error:
"Error creating XML Parser"
Can anyone help with this one? (Version 7.1 Build 832)
Many thanks, Chris
Re: Error launching EA
« Reply #1 on: February 12, 2010, 03:18:35 pm »
Does it stop EA launching?   I've occasionally received it when shutting down EA - I suspect it's because I had multiple copies open and shutting down (at the same time).  Since it wasn't fatal, I just put it down to EAUI.
« Last Edit: February 12, 2010, 03:18:53 pm by PaoloFCantoni »
Aaron B
« Reply #2 on: February 12, 2010, 04:51:00 pm »
What Operating System (and Service Pack) are you running?
This error sometimes indicates that you might need to re-register the msxml dll's on your system.
Try running each of the following commands from the "Run" command under the Windows Start menu:
  regsvr32 msxml3.dll
  regsvr32 msxml4.dll
Another possibility is to install MSXML 4.0 SP2 from the following link:
http://www.microsoft.com/downloads/details.aspx?familyid=3144b72b-b4f2-46da-b4b6-c5d7485f2b42
HTH.
Chris Perrin
« Reply #3 on: February 12, 2010, 04:55:53 pm »
Paolo: Yes it stops EA from launching.
Aaron: Running Windows XP 2002 Professional SP3
Will try re-registering as per your suggestion and get back to you.
thank you both for your help...
Chris.
Chris Perrin
« Reply #4 on: February 16, 2010, 10:41:32 am »
I could re-register msxml3.dll however got the following error from RegSvr32 for msxml4.dll"
LoadLibrary("msxml4.dll") failed - a dynamic link library (DLL) initialization routine failed.
