Author Topic: EA Break Down during drag&drop-Action  (Read 4125 times)
macgoofy
« on: February 26, 2010, 01:49:40 am »
I found two annoying "bugs". First some information about the EA and the current project:
Enterprise Architect (Corporate Edition) Version 7.1.832 (Build 832) - Unicode.
I opened a Model, Logical View with a Logical Diagramm.
Then import by "Import DB Schema from ODBC" a 'huge' Oracle database (around 250-300 tables with constraints etc).
Now the bugs:
1. If I zoomed completly out ("Size View to Page"), mark a few tables/diagramms (around ten) and THEN want to drag&drop them into another space of the diagramm, the application directly close without any warning.
2. If I'm not in the completly "Size View to Page"-Modus but one step inside of it, I can move them, BUT the few tables are 'floating' after the mouse and not at the same speed. I have to click constantly the mouse and 'wave' it, so that the tables can 'float' after the mouse.
These two bugs are the results fot that it always takes a long time to reorder all elements in the diagram :(
And it is very bad, when you've reorderd and edited some tables and then the application closed without warning AND wihtout saving the current changings.
Greetings
macgoofy
Graham_Moir
Re: EA Break Down during drag&drop-Action
« Reply #1 on: February 26, 2010, 02:47:20 am »
Any chance you could try this on more recent versions ?
The current version is 7.5 which has been out for a while and 8 is in beta so it won't be long before it's released.
macgoofy
« Reply #2 on: February 26, 2010, 02:55:53 am »
my company don't have more current versions.
I'm sorry for that.
Were/are the bugs above well-known?
Greetings
macgoofy
« Last Edit: February 26, 2010, 02:56:04 am by macgoofy »
Makulik
« Reply #3 on: February 26, 2010, 03:44:26 am »
You may check the EA version release lists for that. But from 7.1 to 7.5 (850), **phew**, **cough**  :P,  good luck ...
WBR
Günther
