Author Topic: Requirements Report  (Read 4240 times)
nada
Requirements Report
« on: March 03, 2010, 10:37:40 pm »
Is it possible to report only a part of requirements? For example only Validated requirements or only requirements with priority High? Thanks
Graham_Moir
Re: Requirements Report
« Reply #1 on: March 04, 2010, 12:32:39 am »
Well in theory yes.
1) Use the "Model Search" function to find the set of elements you are interested in, e.g. "High Priority" elements.
2) Select all those elements EA finds and puts in the results window,  then right-click and choose "Documentation/RTF report on selected items"  from the menu
3)  The standard RTF document generation dialogue appears,  so you can choose your template etc...   BUT it will operate on the model search results and not on packages in the project browser.
G.
« Reply #2 on: March 04, 2010, 08:15:33 am »
Yes, you can apply filters to your report.  See http://www.sparxsystems.com/uml_tool_guide/reporting_in_enterprise_architect/rtf_element_filters.html although you can also add filters to your template itself.  The process is exactly the same as defining a search.  In fact when editing the filters on a template you can import an existing search.
