Author Topic: Model Document Issue  (Read 3339 times)
Mr. George S
« on: March 10, 2010, 06:58:07 am »
When you create an RTF template that contains requirement, constraint, and scenario elements:
If you run an RTF report over a model document that contains the package where the use case is, only the general tab and scenario information is in the output.
If you run the same template over a package that contains the use case, all the tab elements are in the output (general, constraint, requirement, scenario)
« Last Edit: March 13, 2010, 06:04:21 am by gspecto »
