Author Topic: More in the scenarios and requirements window  (Read 3581 times)
SomersetGraham
« on: March 12, 2010, 02:38:32 am »
Hi
I have a use case that has a note linked.
I have set the link to display All Scenarios
If I update a scenario within the use case properties box the note is also updated
If I update the scenario in the scenarios and requirements window the change is not made to the note.
If I open and close the use case properties box the changes made in the scanraios and requiermetns window are reflected in the note
Using V12
Re: More in the scenarios and requirements window
« Reply #1 on: March 12, 2010, 10:11:23 am »
Hi Graham,
EA has a continuing problem with this type of synchronization.  Formally report a bug so the Sparxians can get to it...
SomersetGraham
« Reply #2 on: March 12, 2010, 07:12:55 pm »
Done!!  :)
Using V12
