Author Topic: MySQL and VARCHAR > 255 character  (Read 3686 times)
awi
« on: March 16, 2010, 11:24:37 pm »
Hi
I try to create a VARCHAR-field in a db-model. I selected as db-type MySQL and now I can create only VARCHAR <= 255 character. But I want create a VARCHAR-field with 1000 character.
I found in the www that older MySQL-versions could max. 255 character, but newer versions over 65thousand.
Have somebody a idee what I can do that EA acept more then 255 character?
Thanks for any help.
andreas
Re: MySQL and VARCHAR > 255 character
« Reply #1 on: March 17, 2010, 09:58:01 am »
Hi Awi,
I'd export the datatypes using Tools|Export Reference Data.  Then I'd edit the relevant portion of the XML.  Finally I'd re-import the changed XML.
If you feel braver, you can edit the t_datatypes table directly.
awi
« Reply #2 on: March 18, 2010, 06:02:21 am »
Hi Paolo
Thank you very much. That works fine!  ;)
I changed the xml and after restart EA it was ok.
Andreas
