Author Topic: RTF Docuement Generation Issue - Diagram Element  (Read 3526 times)
Mike Zhang
« on: March 12, 2010, 11:25:49 am »
EA version: 7.5.844
Issue: It always includes elements of diagrams in the generated RTF document when the template has Diagram|Element checked, regardless whether the "Document each contained element in RTF" flag of a diagram is checked or not. This is annoying because we want elements in some diagrams to be documented in RTF but not all, and if an element appears in multiple diagrams, it is documented multiple times in RTF.
suki
Re: RTF Docuement Generation Issue - Diagram Eleme
« Reply #1 on: March 25, 2010, 09:21:00 pm »
In EA 7.5.xxx version was a new option added .
When you start to generate your RTF document (F8) you can decide to check or uncheck this new option named 'Include all Diagram Elements in Report'.
Behavior of this option is similar like in diagram properties (Document each contained element in RTF) but if checked here then all elements contained in all your diagrams will be described, no matter which settings is in diagram properties.
So, if you need to control for some diagrams only, then uncheck this option on F8 screen.
« Last Edit: March 25, 2010, 09:29:56 pm by suki »
