Author Topic: Error creating new project in PostgresQL  (Read 7182 times)
Darren Barrett
« on: March 25, 2010, 11:01:42 am »
I have a new Postgres 8.4 database created on a Solaris operating system and have recently installed the 8.4.2 ODBC Driver on my PC. I have created the EA repository schema as per http://www.sparxsystems.com.au/resources/corporate/index.html#sql_scripts
I am running version 7.5.847 of Enterprise Architect.
I am wanting to create a new project in my Postgres repository, so I create a new project on my file system and attempt to transfer the empty project to Postgres. Part way through the project transfer exercise I get the following error
"An error has occurred: Microsoft Cursor Engine [-2147467259]
Data provider or other service returned an E_FAIL status.
[Select * from t_umlpattern]
Field: version
Press OK to continue to next row (this record will be lost). Cancel to abort"
hd
Re: Error creating new project in PostgresQL
« Reply #1 on: March 25, 2010, 11:29:53 am »
If you're not using the UML Patterns, open the empty eap project, delete the UML Patterns from the Resources view, and transfer again.
« Reply #2 on: March 25, 2010, 11:31:16 am »
The t_umlpattern table has been named as the culprit, so I suspect the problem is that one of the patterns in your database(*) has a preview image that is too big to save in the Postgres database. I have heard of this being a problem with OpenEdge repositories which have quite a small maximum field size.
Presumably you hit OK and everything else transferred without problem?
(*)My money's on the Gang of Four abstract factory pattern.
Darren Barrett
« Reply #3 on: March 25, 2010, 01:42:19 pm »
Thanks guys..... I will delete the uml patterns as you suggest and give it a try.
Darren Barrett
« Reply #4 on: March 25, 2010, 01:57:33 pm »
Unfortunately I am now getting a terminal error when I attempt the project transfer:
"Runtime Error!
Program: C:\Program Files\Sparx Systems\EA\EA.exe
abnormal program termination"
hd
« Reply #5 on: March 25, 2010, 02:59:19 pm »
I noticed you're using PostgreSQL 8.4.
Thers's a note in the EA User Guide...
http://www.sparxsystems.com/uml_tool_guide/uml_model_management/setupapostgresqlodbcdriver.html
Note: Do not use version 8.4.1 of the PostgreSQL ODBC Driver - it has issues transferring a project to a PostgreSQL repository.
Could that be your problem?
Darren Barrett
« Reply #6 on: March 25, 2010, 03:49:12 pm »
Hi.... thanks for the reply.
I also noticed the flag on the 8.4.1 version of the ODBC driver. The version of the Postgres database is 8.4 and I am using the 8.4.2 version of the ODBC driver. I have also tried the most recent 8.3 version of the driver with the same result.
Cheers,
Darren.
Darren Barrett
« Reply #7 on: March 30, 2010, 05:42:00 pm »
Found the fix to this problem. Following URL discusses how to configure the data source for use with EA.
Perhaps it would make sense to reference this in the DBMS Repository Setup Scripts instruction section for PostgresQL.
