Author Topic: Copy-paste diagram in build 854 meshups  (Read 3674 times)
Edward
« on: April 01, 2010, 12:40:15 am »
I use the beta 3 of EA 8, build 854. If I copy and paste a (large) diagram, the connections are not shown correctly in the other application (like Word).
This was also in beta 1 and 2.
bash
Re: Copy-paste diagram in build 854 meshups
« Reply #1 on: April 01, 2010, 04:28:33 am »
Are you using the Edit|Select All before you copy and paste?  If you're just using Word to copy it into just generate the diagram as an RTF document and copy that directly over into whatever else you're using.
Aaron B
« Reply #2 on: April 01, 2010, 11:02:46 am »
Can you confirm what your Clipboard Format is currently set to?  (See Tools | Options)
If your clipboard format is currently set to Metafile, try changing to Bitmap and then copy and paste your diagram again.  Any difference?
