Author Topic: 854: Notes visibility inconsistent  (Read 4086 times)
« on: April 02, 2010, 08:39:53 pm »
I'm not sure if this bug was introduced in the v8 Beta, but it's the first time I've noticed it.
If you set a diagram to show attributes and operations and then using Set Feature Visibility [Ctrl+Shift+Y] to inhibit their display - they won't display.  However, if you attempt the same with Notes, they STILL display.
The behaviour should be consistent.  If you explicitly inhibit the rendering of Notes (via - if necessary - marking and then unmarking the checkbox in the dialog) EA should respect your requirement for that element (including packages).
Reported,
