Author Topic: Spell Check - cannot add new word to dictionary  (Read 8404 times)
Ainsley Haslett
« on: May 04, 2010, 12:26:26 pm »
Im spell checking my ea model and when a word comes up that is relevant to my industry I would like to add it to the dictionary - but this fails with the following message
"Can't add work to user dictionary. File may be read only or disk may be full"
The current project is a SQL based EA model. I've had the exact same problem with the .eap file approach.
How can I overcome this as I need to add our local tech terms to the model so we don't have to have them appear as errors every time? ::)
Re: Spell Check - cannot add new word to dictionar
« Reply #1 on: May 04, 2010, 12:58:13 pm »
Hi Ainsley,
This happened to me recently.  EA uses the Wintertree spelling engine and somehow (probably moving the exiting dictionary between machines) I managed to stuff up the access to the dictionary files.
Make sure you have write access to the .tlx files in your .AppData paths.
Aaron B
« Reply #2 on: May 04, 2010, 01:11:37 pm »
Hi Ainsley,
What Operating System and EA version are you using?  Dictionaries used to be stored under the install directory (Program Files), which users under Windows Vista / 7 don't have write access to by default.  EA 8.0 now stores custom dictionaries under the user profile (AppData) area instead, which you should have write access to.
Ainsley Haslett
« Reply #3 on: May 04, 2010, 01:14:26 pm »
Hi there. THanks to the both of you. I have windows XP and we have a relatively highly locked down environment here at work e.g. I can't view Program Files so I guess that's the problem. I'm having a tech here look into your suggestion.
Thanks again, will post how I get on!
