Author Topic: Package.Elements doesn't return all elements  (Read 22775 times)
Re: Package.Elements doesn't return all elements
« Reply #15 on: April 20, 2010, 11:46:41 pm »
At least one instance where EA (7.5.850) creates the NULL parentID values is the deep copy of a diagram.
Every element that gets copied, and was previously nested under an element now has a NULL value as parentID.
Steps to reproduce:
1. Create a diagram nested under elementA
2. Add new object objectA on the diagram using the toolbox
3. Copy the diagram
4. Select a package and paste the diagram (choose deep copy)
5. Investigate the t_object table and notice that there are now new rows with parentID is NULL
[edit]Same thing in 8.0.855[/edit]
« Last Edit: April 20, 2010, 11:51:14 pm by Geert.Bellekens »
« Reply #16 on: April 21, 2010, 02:09:02 am »
I presume you've reported it?
« Reply #17 on: April 21, 2010, 02:02:11 pm »
Yep
« Reply #18 on: May 05, 2010, 05:13:56 pm »
According to the release notes this issue should have been fixed in v 8.0.856. I haven't tested it myself though.
