Author Topic: Tagged values nonsense  (Read 3562 times)
beginner
« on: May 07, 2010, 01:02:46 am »
When you create an arbitrary Tagged Value and edit the notes (not the value) of that, set it to 'Values: a,b,c' (without quotes). That will turn it into a dropdown list with the three values a, b and c. This is so silly, it's another perfect EAUI. There IS a table t_propertytypes. Why in heaven is this information stored in the Notes column and not in a dedicated one???? Trash by Design.
b.
P.S.: another on in that line: Type=DateTime; says you can enter date and time. In fact you can ONLY select the date. Either the time gets available or it should be Type=Date;
« Last Edit: May 07, 2010, 01:06:17 am by beginner »
Re: Tagged values nonsense
« Reply #1 on: May 07, 2010, 05:59:38 pm »
Great! :o
That is similar to the magic <memo> in the value.
beginner
« Reply #2 on: May 07, 2010, 09:20:34 pm »
Yep. I forgot to mention that. I just sent a couple of tag-related issues to Sparx. The places where lack of design is obvious now covers almost all regions of EA. So many new gadgets. The fewest working half-ways correctly. Most of them (heavily) buggy. Still a lot of bugs from the past. If EA were a used car I would wreck it, not put additional ornaments on top.
b.
